Syvecs S8 Pinouts PDF
Jasper K
Post by Jasper K »
Hi Gents,
I made a Pinouts PDF to visualize all Pins on the S8 ECU and have used colors to visualize all potential "Groups" of functionality.
Hope it provides some assistance to anybody making looms.
Jasper Kopinga
CS Racing
Taiwan
Syvecs_S8_pins.pdf
Syvecs S8 Pinout
(7.82 KiB) Downloaded 2179 times
Gizmo
Re: Syvecs S8 Pinouts PDF
Post by Gizmo »
Thanks Jasper, that's very helpful !!
---john---
Benkku
Post by Benkku »
Caveat emptor - for example, there is 16 fuel injectors in list, but 14 in location map.
pavlo
Zen Performance
Post by pavlo »
There are 16 in both. 2 of the injector outputs are on low current pins.
Jasper K
Post by Jasper K »
There are certainly 16 Fuel Ouputs in the list.
As Paul mentioned 2 are on Pins #47 and #20 and since they are located close to Lam#1 and Lam#2 they are best used as Lambda Heaters and I'm quite sure that was what the designers had in mind ;-)
Jasper.
Benkku
Post by Benkku »
Yes, indeed - i just 'stared and counted those wider ones', so didn't notice. :oops:
tarmac terror
Post by tarmac terror »
What are the chances of a Pinout and wiring guide ala the S6GP one ?? viewtopic.php?f=6&t=401
TT
