Syvecs iPhone / iPad App - Classic
For support and updates on the Syvecs Bluetooth module
Moderator: Wez
Wez
Santa's Little Helper
Post by Wez »
Hello All,
You may have seen there is a Syvecs app now available on the Apple App store.
The initial release uses either the stack stream or a fixed custom can stream via rs232 output, this is via the Syvecs Apple approved bluetooth module. The fixed can profile is based on the most commonly used setup from Syvecs.
I am currently working on a new release that has the following features :-
* User Assignable Display Output
* User Configurable CAN profile
* High / Low Peak Values
* Unit Selection
* Calibration Switching via PWM output
* Traction Control Switching via PWM output
* User Configurable Switch Output via 0-5v output
8-)
Wez
Re: Syvecs iPhone / iPad App
Post by Wez »
Little update 8-)
The output function is now working from within the App, there are two available that can be used for calibration and traction control switching with ten positions for each, just need to finish up the interface, this uses two inputs on the ECU.
http://www.youtube.com/watch?v=wSCwIxMrmcA
secure
Post by secure »
Good job! Now I can switch to ipad from carpc.
I doubt I have spare input. Which inputs it uses and why two?
Wez
Post by Wez »
secure wrote:Good job! Now I can switch to ipad from carpc.
This version allows you to replace the two inputs into the ECU that you are currently using for calibration and traction control switches.
Steve
Re: Syvecs iPhone / iPad App Chat
Post by Steve »
Any update to our phone call Wez?
:D
Toyota Supra BoostLab S366HF - 821 rhhp / 644 ftlbs - Mapped by Ryan
Syvecs S6 with aftermarket DBW setup on Greddy Style Intake manifold.
- SOLD 2017
Wez
Post by Wez »
Steve wrote:Any update to our phone call Wez?
:D
We are looking to implement cal and trc switching via rs232, im not sure on timescales, Ryan may have a better idea as it would require a firmware update for the ECU.
Regarding the ability to remember the last position a firmware update could be applied to the BT module where it was using the cal and trc outputs wired from the module.
secure
Post by secure »
I can't rotate the screen on IPAD mini? No landscape mode on ipad mini?
Wez
Post by Wez »
Works OK here on my mini, which screen are you trying to rotate and which version you running?
EDIT: which iOS version also?
secure
Post by secure »
It was the latest Syvecs version. I just updated to latest ios version and it works now!
Regarding for the interface. can we use custom shiny gauges in the future like that? :D
Wez
Post by Wez »
I am currently working on a new cross platform release with more features ;)
Return to “Syvecs Bluetooth Module”
