Long tooth gap
For Subaru Technical Chat
Motoka
Long tooth gap
Post by Motoka »
Sorry to hog the forum folks. I thought I had sorted all my tuning niggles with Paul's kind advice but now have picked up a long tooth gap error. It has appeared when driving under boost/high rpm rather than cruise and does not appear to be cranking related. I did not get any cough etc but noticed it on the log. I ran a sync log following at the end of the run when I picked up the error (attached). What should I be looking for on the sync log to diagnose this? Any advice greatly appreciated cheers.
LTG error1.txt
(272.2 KiB) Downloaded 1173 times
pavlo
Zen Performance
Re: Long tooth gap
Post by pavlo »
That's just the startup log, can you post the error log, go to "Device->View Sync Log" and then click on "sycnError" or press the "E" key.
Check you're wiring, plug latch etc the normal things, might be the sensor itself too.
Motoka
Re: Long tooth gap
Post by Motoka »
Thanks Paul I swapped on another sensor and no more error :)
