What ECU did you run before Syvecs? Should I buy one?
Re: What ECU did you run before Syvecs? Should I buy one?
Sun in the UK ??
It really isnt a major problem lol
stevieturbo wrote:I/O Expander offers more I/O's but also eats into the CAN stream I presume ?
Not sure how that affects it's ability to talk to a dash for example ?
Yes and no...the "normal" datastream is still present, but the CAN is run at a non-standard rate; but the Syvecs I/O10 has a secondary CAN port that re-sends the usual datastream out at 1Mbit/s. So should be OK there.
For the benefit of those who don't know or are after a solution and must have 12bitAD for certain sensor logging applications, then you can use the X10 expansion box, this will give 10 extra AN input channels at up to 500hz sample rate.
