Worksheet and Layout Export/Import
KulinPapa
Post by KulinPapa »
Could it be possible to make Exportable and Importable the Gauge Layouts in SCal, and the Worksheets in SView ? It takes several hours to migrate the settings when needs to change to a new laptop.
Syvecs Staff - Cleaner
Re: Worksheet and Layout Export/Import
Post by pat »
Hi there!
I believe this is on the ToDo list, you're not alone in requesting it so watch this space :) In the meantime you can probably achieve the result that you want by copying the registry tree for the SCal application from the original machine to the one that wants a copy of your settings. Less user friendly but it will save some time.
See here, it doesnt take hours...but it does still need a proper solution
viewtopic.php?f=19&t=678&p=3603
