Hello,
Ich have Problem with my ecu,
When i start the engine , and wait 60 seconds (Every Time 60 seconds!) the the engine Turns off automatic ..
Anyone has a idea?
greetz
S8 pnp automatic engine off
Re: S8 pnp automatic engine off
here is a log, i dont find the problem :/
maybe anyone can help me
- log1minuteproblem.SD
- (328.68 KiB) Downloaded 1279 times
Its pretty easy, ECP trip is active.
What will help you is setting up a screen as I show below.
If you send me your calibration file I can amend it for you to stop this, its an easy fix.
hey here is a file
can you explain what is ecp trip is?
- 1 minute map.SC
- (476.99 KiB) Downloaded 1350 times
An acronym 'ecp' short for Engine Coolant Pressure and TRIP means it will trip (active limit condtions) the run mode of the engine, you can limp it to various lower rpm limits or stop it (set by the calibrator).
I'll take a look at your file now, in mean time if you want to write back here is this your first time using this type of ECU? Even if not there is allot of information around in various forms to suit all kinds of learning preferences IE: video's and good basic manual that describes functions, nomenclature and a fair few applications.
Until today, I have worked with ECUs such as Ecu Master KMS and adaptronic.
Syvecs is of course a completely different league the names are also quite different, but I am sure synvecs synonymous I will learn =)
So you have no ECP sensor allocated in your I/O.
When one is not hooked up you will find that input will sit at ~2.5v or so, thus looking at the linearization look up that means it would trigger the high ECP value after the set run time of one minute which then is set to shut down the engine.
So I just set your 'high value' to be 90psi which means it should not trigger that after 1 minute has passed.
You can do a file compare to see the differences and also wrote that in your notes section as well in the calibration file.
When running the car go the the sensors area and click on the value and the voltage and you will see what I typed above hopefully.
Good luck with it, long learning curve but you have to start somewhere
- 1 minute map RR.SC
- (476.99 KiB) Downloaded 1239 times
pics to help
thank you very much for your help =)
i test it now =)
i test it now =)
