connect a cutout exhaust
SYS973
Post by SYS973 »
hello
i want know if is possible connect a solenoid for control cutout ?
possible use water injection output ?
i/o configuration use PIN A25 ?
control ground ?
solenoide 12V ?
thx
Re: connect a cutout exhaust
What you can connect, depends which output you wish to use and how much current it will draw. "pinA25" doesnt really mean much without more info. You may need to control it indirectly via a relay....and would probably be more sensible to do this anyway
But yes the output will switch to ground for either the solenoid, or preferred a relay.
As to whether water injection strategies are the best choice to actually turn that output off/on, is another matter but I'm sure it could be used.
SYS973
Post by SYS973 »
hello
i use a oem solenoid vacuum control use in audi oem control by ecu oem too
i suppose no need relay
lower then 1 amp
