fastest starting settings
What settings do you use to get the engine started fast. Starting waits for 720 Sync? Fast phase Sync? or other settings?
Re: fastest starting settings
Do not wait for 720 sync
Some crank triggers may lend themselves better than others for a fast start
Maintaining fuel pressure on shutdown will also help a little ( pump/reg dependent )
How fast/slow is yours at present ? Syncscope should let you see how many revolutions before fire
Here is the synclog
- synclog.txt
- (285.63 KiB) Downloaded 2008 times
around 7-8 turns ?
Although it looks like it does sync up fairly quickly....rpm does increase, but perhaps not idle speed but seems faster than cranking on the starter, then eventually it runs normally ?
Is it any different hot or cold ?
How is fuel pressure for the start ?
