Hi, when operating a Pierburg at the recommended 35Hz what's the max/min usable duty (i.e. what's the dead zone top and bottom)?
Thanks.
Syvecs Boost Solenoid Plumbing Info
Re: Syvecs Boost Solenoid Plumbing Info
This is a car with one Pieburg valve set up and one MAC valve, phase anit phase. Have good control from 5% to over 95% 31Hz setting on this one.
- screenshot.2.jpg (568.76 KiB) Viewed 42346 times
- screenshot.1.jpg (555.01 KiB) Viewed 42346 times
Did you run the MAC valve at the same frequency?
Cheers.
Cheers.
yes
