Syvecs Boost Solenoid Plumbing Info
crice
Re: Syvecs Boost Solenoid Plumbing Info
Post by crice »
Hi, when operating a Pierburg at the recommended 35Hz what's the max/min usable duty (i.e. what's the dead zone top and bottom)?
Thanks.
This is a car with one Pieburg valve set up and one MAC valve, phase anit phase. Have good control from 5% to over 95% 31Hz setting on this one.
crice
Post by crice »
Did you run the MAC valve at the same frequency?
Cheers.
crice wrote: Tue Nov 17, 2020 11:39 am Did you run the MAC valve at the same frequency?
Cheers.
yes
