The latest Huracan/R8 AWD Base map which matches the latest firmware can be found below in Attachments
Latest Base Map
Latest Base Map
- AwdBase_HuracanR8 1.14.SC
- (37.21 KiB) Downloaded 2014 times
Re: Latest Base Map
1.15 Firmware Base Map
- AwdBase_HuracanR8 1.15.SC
- (41.62 KiB) Downloaded 2091 times
1.18
- AwdBase_HuracanR8 1.18.SC
- (42.89 KiB) Downloaded 2139 times
1.21 Base Map
For use with 1.21 Firmware
- AwdBase_HuracanR8 1.21.SC
- (48.05 KiB) Downloaded 1982 times
1.23 Base Maps
For use with 1.23 Firmwares
- AwdBase_HuracanR8 1.23 X4.SC
- (51.46 KiB) Downloaded 2021 times
- AwdBase_HuracanR8 1.23.SC
- (51.46 KiB) Downloaded 1985 times
1.24 Base Maps
For use with 1.24 Firmwares
- AwdBase_HuracanR8 1.24 X4.SC
- (55.78 KiB) Downloaded 2175 times
- AwdBase_HuracanR8 1.24.SC
- (55.83 KiB) Downloaded 1922 times
1.25
- AwdBase_HuracanR8 1.25 X4.SC
- (61.05 KiB) Downloaded 1929 times
Re: Latest Base Map
For use with 1.27 Firmwares
- AwdBase_HuracanR8 1.27 X4.SC
- (66.87 KiB) Downloaded 1608 times
- AwdBase_HuracanR8 1.27.SC
- (66.84 KiB) Downloaded 1575 times
Re: Latest Base Map
For use with 1.28 Firmwares
- AwdBase_HuracanR8 1.28 X4.SC
- (72.44 KiB) Downloaded 1265 times
Re: Latest Base Map
1.29 base map
- AwdBase_HuracanR8 1.29 X4.SC
- (72.89 KiB) Downloaded 1275 times
