Latest Base Map
Technical Help / Firmwares for the VAG MQB Range - Audi RS3 / TTRS
Locked
Latest Base Map
The latest VAG MQB AWD Base map which matches the latest firmware can be found below in Attachments
This base map limits the Max duty to 70%, Some users of the Rs3 Kit from Iroz motorsport have the duty limits at 80% or even 90%. You will need to adjust in Scal to Suit
AwdBase_RS3 1.14.SC
(37.21 KiB) Downloaded 4385 times
1.15
1.15 Firmware Base Map
AwdBase_RS3 1.15.SC
(38.8 KiB) Downloaded 4113 times
1.18
AwdBase_RS3 1.18.SC
(42.89 KiB) Downloaded 4194 times
1.21 Base Map
For use with 1.21 Firmware
AwdBase_RS3 1.21.SC
(46.26 KiB) Downloaded 4057 times
1.23 Base Maps
For use with 1.23 Firmwares
AwdBase_RS3 1.23.SC
(51.46 KiB) Downloaded 4206 times
AwdBase_RS3 1.23 X4.SC
(51.46 KiB) Downloaded 4153 times
1.24 Base Maps
For use with 1.24 Firmwares
AwdBase_RS3 1.24.SC
(55.83 KiB) Downloaded 4003 times
AwdBase_RS3 1.24 X4.SC
(55.78 KiB) Downloaded 4045 times
1.25
AwdBase_RS3 1.25 X4.SC
(61.05 KiB) Downloaded 4096 times
Re: Latest Base Map
For use with 1.27 Firmwares
AwdBase_RS3 1.27.SC
(66.84 KiB) Downloaded 2253 times
AwdBase_RS3 1.27 X4.SC
(66.87 KiB) Downloaded 2315 times
Re: Latest Base Map
For use with 1.28 Firmwares
AwdBase_RS3 1.28 X4.SC
(72.44 KiB) Downloaded 1898 times
Re: Latest Base Map
For use with 1.29 Firmwares
AwdBase_RS3 1.29 X4.SC
(72.89 KiB) Downloaded 2235 times
Locked
Return to “VAG MQB5 Range - Audi RS3 / TTRS”
