Hi all,
I am trying to wire S6Gp to Honda K24 turbo. I am not able to figure out which pin can be used to run Vtec output. I think i should use a relay and use any pull down to supply 12v to switch Vtec on. This has only one Vtec in the intake. No exhaust Vtec.
I can see variable valve timing exhaust A and inlet A assigned to Slave1 Out #01 and #02 respectively in the pin assignments in the basemap that I was supplied. I don't have any expander box. What do these pins refer to?
Mahesh.
K24 S6GP wiring
Re: K24 S6GP wiring
thanks mate. replied. attaching map.
- K20A2 Basemap startup erro free-094.SC
- (391.83 KiB) Downloaded 1030 times
