Hey neex help connecting to syvecs
Twinturbosyvecs
Hey guys So i tried 2 dif laptops and 1 pc to connect to syvecs s12
When i try to connect to syvecs i have it on table all power and ground connected and the 4 ethernet wires
Software says no device found
I am using win 11
My pc shows a network is opened and there is a ip address populated
Please help thank you
I am using win 11
- 67CB71C8-C1C2-4CA9-A5A7-081B8F3BF4C8.jpeg (882.99 KiB) Viewed 17149 times
- 80FB2B08-0BAA-42BA-B96E-0A0DF966A7D8.jpeg (797.75 KiB) Viewed 17149 times
- D50D34A9-F370-40E4-B1CF-57B71083D696.jpeg (290.88 KiB) Viewed 17149 times
Re: Hey neex help connecting to syvecs
Annoyingly, sometimes mine will not connect.
I simply re-install the software, it only takes a few seconds and then it will connect.
This appears to happen at random. Sometimes it works fine, sometimes it just does not.
Power everything up as normal, re-install the SSuite software and see if that changes anything
Twinturbosyvecs
Tried that and tried 3 different pcs
2 laptops with usb ethernet and 1 with desktop
If you open SMsgs, or SMon does it attempt to connect ?
Are you sure the ecu is definitely powered up and live ? and ethernet cable wired correctly ?
Twinturbosyvecs
Yes it does and it gives ip address
And it does try connecting but shows no devices are available
Can't comment on whether it should or should not appear like that.
I've plugged a spare ecu into a Wifi router, and when connected to my W11 PC sitting here via WiFi, this is how my config appears, 5G Wifi connection
And annoyingly...again the RTC clock battery is flat. This was changed only a year ago !
and from control panel info
Twinturbosyvecs
Thanks alot for the info
On the table which pins are you connecting?
3 power 5 ground? And the 4 network?
Which syvecs do you have.
This is an S8 I have for bench testing.
But on an S12, yes any power ground and battery supply should do for power, and the 4 LAN pins
http://www.syvecs.com/downloads/S12_Pin ... g_Info.pdf
Twinturbosyvecs
So still no device found
Tried 3 computers at this point, 2 different usb to ethernet and 1 pc with built in ethernet
Reinstalled software still nothing
I also confirmed 5 volt out is working
Any ideas ? This is crazy
