s7p n54 sync error
taronsargsyan
s7p n54 sync error
Post by taronsargsyan »
Hi
I have started playing with some values to make my hot start good enough. I have started getting sync error just a bit later when runmode changes to running.
looks like reducing timing during the start make the ecu to not sync properly. Is this something expected by means of the physics ?
see attached logs
regards
2023-08-27 14-26-53 plus 0h00m00s S7#12516.SD
(525.94 KiB) Downloaded 805 times
last-sync-log.txt
(280.18 KiB) Downloaded 819 times
taronsargsyan
Re: s7p n54 sync error
I have seen several errors. Long tooth gap and cam error.
