Latest Firmware Releases
Technical Help / Firmwares for the VAG MQB4 Range of AWD Controllers
Locked
Ryan.g
Syvecs Staff - Caretaker
Post by Ryan.g »
This thread is for tracking the firmware builds of the AWD Audi MQB5 units. When a new release is available it will be added to the end of this thread.
Ryan.g
Re: Latest Firmware Releases
Post by Ryan.g »
Changes since 1.23.3:
OLD BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/AWD_MQB4_1-24-4.enc
NEW BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/X4AWD_MQB4_1-24-4.enc
Ryan.g
1.25
Post by Ryan.g »
Changes since 1.24.4:
OLD BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/AWD_MQB4_1-25-1.enc
NEW BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/X4AWD_MQB4_1-25-1.enc
Ryan.g
Post by Ryan.g »
Changes since 1.25.1:
* Added LatG Duty Adjustment
OLD BOARD - Firmware Version 1.27.1 - https://www.syvecs.com/downloads/AWD_MQB4_1-27-1.enc
NEW BOARD - Firmware Version 1.27.1 - https://www.syvecs.com/downloads/X4AWD_MQB4_1-27-1.enc
Ryan.g
1.29 Firmware Release
Post by Ryan.g »
* Only Awd Pressure is read from Hall input if Huracan or 991 AWD build
* USB Datalogging
* Programming fix
Please ensure you are using the Latest Ssuite software which has USB support - viewtopic.php?f=8&t=122
OLD BOARD - Firmware Version 1.29.1 - https://www.syvecs.com/downloads/AWD_MQB4_1-29-1.enc
NEW BOARD - Firmware Version 1.29.1 - https://www.syvecs.com/downloads/X4AWD_MQB4_1-29-1.enc
Locked
Return to “VAG MQB4 Range - Golf R7, Audi S3”
