Latest Base Map
Technical Help / Firmwares for the Nissan R35GTR Awd Controller
Locked
Latest Base Map
The latest Nissan R35GTR AWD Base map which matches the latest firmware can be found below in Attachments
AwdBase_GTR 1.14.SC
(37.21 KiB) Downloaded 4715 times
1.15
1.15 Firmware Latest base map
AwdBase_GTR 1.15.SC
(38.8 KiB) Downloaded 4267 times
1.18
AwdBase_GTR 1.18.SC
(42.89 KiB) Downloaded 4393 times
1.21 Base Map
For use with 1.21 Firmware
AwdBase_GTR 1.21.SC
(46.26 KiB) Downloaded 4387 times
1.23 Base Maps
For use with 1.23 Firmwares
AwdBase_GTR 1.23.SC
(51.46 KiB) Downloaded 4569 times
AwdBase_GTR 1.23 X4.SC
(51.46 KiB) Downloaded 4205 times
1.24 Base Maps
For use with 1.24 Firmwares
AwdBase_GTR 1.24.SC
(55.83 KiB) Downloaded 4367 times
AwdBase_GTR 1.24 X4.SC
(55.78 KiB) Downloaded 4277 times
1.25
AwdBase_GTR 1.25 X4.SC
(61.05 KiB) Downloaded 4053 times
Re: Latest Base Map
For use with 1.27 Firmwares
AwdBase_GTR 1.27.SC
(66.84 KiB) Downloaded 2334 times
AwdBase_GTR 1.27 X4.SC
(66.87 KiB) Downloaded 2203 times
Re: Latest Base Map
For use with 1.28 Firmwares
AwdBase_GTR 1.28 X4.SC
(72.44 KiB) Downloaded 1893 times
Re: Latest Base Map
1.29 Base map
AwdBase_GTR 1.29 X4.SC
(72.89 KiB) Downloaded 1058 times
Locked
