Latest Firmware Releases
The Syvecs 2.4 Inch TinyDash is a compact competitively priced display designed as an easy to install and convenient source of vital information from your powertrain control system.
Re: Latest Firmware Releases
Updating the TinyDash is done via a USB C cable on the back and using our Syvecs Updater Program -https://www.syvecs.com/downloads/Syvecs_Updater.pdf
Must use the Latest Ssuite Software found here - viewtopic.php?t=122
Any further Questions please E-mail support@syvecs.co.uk or speak to your nearest dealer
- Flex Can Transmit map starts at bit 0
- Flex Can Transmit Change to allow Scaling and Offset
See help video on new CAN Changes here - https://youtu.be/8Yn1JitpXN0
Release 1.25.1 ---- https://www.syvecs.com/downloads/TinyDash_1-24-2.enc
- Added auto detection of Touch screen
- Added Knock Channels
- Added Fuel Level Item
- Selection options under calibration switch to select how CalSelect and EcuCalSelect is set
Release 1.30.2 ---- https://www.syvecs.com/downloads/TinyDash_1-30-2.enc
Changes in latest release:
- Added WMI, LAM2CAN, GPS and KT8 Receive options
- Fixed issues with Screen Rotations
- Changes to Touch Z1 and Z2 detection for more accuracy
- BugFix with Layout5 and Multiple Item Sets
Release 1.32.2 ---- https://www.syvecs.com/downloads/TinyDash_1-32-2.enc
- BugFix with Logging item drop outs in LCD Display 3+
- BugFix with Wastegate control duty lookup in Open loop mode
- Added EcuTCSelect so Map switching screen so does effect inbound TCSelect Values
- Added ALSSelect into CAN Transmit options
- 29Bit Extended CAN support
- Supra 2020+ CAN
- Bmw2020+ CAN
Release 1.35.1 ---- https://www.syvecs.com/downloads/TinyDash_1.35.1.enc
1.36 - Alarm Enable Selection
1.37 - Alarm Delay 500ms added
1.38 - Added OEX CAN RX
1.38 - BugFix for Frozen ADC Signals
Release 1.38.1 ---- https://www.syvecs.com/downloads/TinyDash_1.38.1.enc
1.39.2 - Programming adjustment to make more stable with poor USB cables
Release 1.39.2 ---- https://www.syvecs.com/downloads/TinyDash_1.39.2.enc
Locked
