Hey neex help connecting to syvecs
Re: Hey neex help connecting to syvecs
Again, confirm RJ45 cable is wired correctly.
Twinturbosyvecs
Post by Twinturbosyvecs »
Matches the diagram i tried even reversing 2 greens with 2 oranges same result
secure
Post by secure »
Most of the USB ethernet devices won't work with Syvecs from my experience.
I would suggest you to try another Windows 10 computer with built in ethernet + readymade ethernet cable.
Twinturbosyvecs
Hi i tried 2 laptops windows 10
1 desktop windows 10 with built in ethernet so mo ethernet adapter
Twinturbosyvecs
Also just tried syvecs wifi adapter same thing
I can only suggest to have the supplying dealer to check the ecu out to see if they can have any luck. If it is not the cable, and the ecu is powered up....it seems rather unlikely all the computers are faulty.
I would be amazed if the ecu is faulty without some causation though. But your supplying dealer should be able to check it out.
secure
Post by secure »
Do you see an adapter when you open SNetServer? (run as administrator)
Twinturbosyvecs
Yes i do
Today tried another pc with same results will be sending to wayne to diagnose
