Page 12 of 14
Posted: Sat Apr 29, 2023 4:36 am
And another one, a 'mild' street car set up with ~1870+hp on chassis dyno.
All other probes
thrown in bin as these (customers words) are only ones worth using cause they actually respond in time, show what is happening, and to date not a single one needing to be replaced.
Any small setting difference is immediately reported, as are ignition miss fires, stop guessing, go
donmega!
- donprobesyolez.jpeg (166.15 KiB) Viewed 128842 times
- isdonisgood.jpg (642.34 KiB) Viewed 128842 times
Posted: Tue May 02, 2023 4:06 pm
STREET CAR
fact v fiction, cause no one races on a dyno !
when you really need probes that will do what no others can, there is only one, the donmega !
- don probes track yo!.jpeg (82.48 KiB) Viewed 128820 times
- dyno v track donmega.jpg (940.75 KiB) Viewed 128820 times
Posted: Wed May 03, 2023 5:59 am
REAL STREET CAR
Full length exhaust, no homo side pipes or cut outs
Power in reality matches dyno claims,, no fake fuel flow model 'guessed' numbers
Durability and accurate engine settings only offered by, tried, tested, & proven
donmega probes
*GET ON IT !*
- 4.5 inch cunts.jpeg (246.11 KiB) Viewed 128812 times
- FT PRO 1.jpg (48.77 KiB) Viewed 128812 times
Posted: Wed May 03, 2023 6:09 pm
What is it ? a Supra or something ? What box ?
7's are flying
Posted: Thu May 04, 2023 1:07 am
stevieturbo wrote: Wed May 03, 2023 6:09 pm
7's are flying
That track run had powerglide
Also ran with a K&N air filter ! and full length exhaust, no NOS used over the 400m either unlike others
was at low boost 60psi ~1600hubhp
- donmega RX7.jpg (632.43 KiB) Viewed 128788 times
Posted: Thu May 04, 2023 3:32 am
Today and another more serious 'race car' with about double the power! swapping over to the
donmega probes, when you really want to know what is going on then these are the FINAL SOLUTION
- FINAL SOLUTION 5.jpeg (239.18 KiB) Viewed 128777 times
- FINAL SOLUTION DONMEGA 3.jpeg (132.33 KiB) Viewed 128777 times
Posted: Thu May 04, 2023 6:17 am
Couple more race cars seeing the light ................
donmega probes for all !
- FINAL SOLUTION 6.jpeg (159.67 KiB) Viewed 128768 times
- FINAL SOLUTION DONMEGA 1.jpeg (149.43 KiB) Viewed 128768 times
Posted: Fri Jun 23, 2023 9:10 pm
An update,
This car running *DONMEGA EGT PROBES* ran 7.17 seconds @ 202+mph yesterday
If you want to run fast consistent and reliably making each cylinder contribute its best on methanol fuels then you should be using a probe that will let you see what is happening ............
https://www.facebook.com/dragimportmedi ... 252899548/
RICE RACING wrote: Wed May 03, 2023 5:59 am
REAL STREET CAR
donmega probes
*GET ON IT !*
Posted: Mon Jun 26, 2023 11:34 pm
https://youtu.be/I33IeZF5ovo
^ Here is video of the pass for those who get hard watching others perform
- 2JZ11.JPG (502.19 KiB) Viewed 124439 times
RICE RACING wrote: Fri Jun 23, 2023 9:10 pm
An update,
Posted: Mon Jul 10, 2023 4:20 am
Have a few more examples to share for the benefit of all following here, some will be more general in nature being applicable to a larger percentage of users, then others for the elite but all of them regardless remove one thing
BLAME GAME !
Try to put it in a format that is understandable (if you are here then you are already one step ahead of most TBF) but should get people more access to what is otherwise closely guarded information that you just don't get on a pay to play education platform or A typical sponsored GagTube rantings
- NOT FLINSTONES PEDAL CAR.jpeg (61.74 KiB) Viewed 120925 times
