Broken link to GPS manual
MikeyB571
Post by MikeyB571 »
I'm trying to access the manual for the Syvecs GPS receiver, however it looks like the link to the manual is broken or its moved.
Can anyone post up a more recent/working link please 👍
http://www.syvecs.com/downloads/Syvecs% ... Module.pdf
thisguy
Re: Broken link to GPS manual
Post by thisguy »
Do you need the 10hz or 50hz manual? Also what info are you after? maybe we can just tell you here.
MikeyB571
Post by MikeyB571 »
I'm looking for the can bus details.
So what the frame IDs, and payloads are for all the GPS and g values.
Any help is appreciated
thisguy
Post by thisguy »
When in the Syvecs software, the GPS CAN receive gets selected in a menu and the CAN frames are populated for you. This happens in the background as you dont get to see or change them. Are you going to use the GPS CAN with a third party device?
MikeyB571
Post by MikeyB571 »
I have another device which I can confgure to output CAN frames, I would need to know the frame IDs to use and how to populate the payload.
So yes, I want to try and use a third party device if possible.
thisguy
Post by thisguy »
PM'D
From the Plex config
plex syvecs can.jpg (29.46 KiB) Viewed 26258 times
MikeyB571
Post by MikeyB571 »
Thanks Tim,
That's exactly what I need :)
