Mounting GPS module
Posted: Sat Jan 11, 2020 5:09 am
by torana
Is there a preferred mounting direction and car position for mounting the syvecs gps module.
Was thinking module plug output towards car front aerial out towards the car rear, and mounting the module centre of the car around handbrake area on the tunnel.
Thx
Re: Mounting GPS module
Posted: Sun Jan 12, 2020 6:30 pm
Must be level and, ideally, central in the car - so in the vicinity of the gearlever/handbrake is right.
The orientation is mandated by the manual - which unhelpfully is nicely vague as directions are described as "x" and "y". I believe it has to be mounted with the connector mounted pointed forwards, but I stand to be corrected on that.
Posted: Wed May 12, 2021 9:42 am
Here is how to mount it, has or should be central in car, near gear lever works on most cars and connector pointing to front of car, also make sure you take time to mount it level in x & y axis or flat, an adjustable mount helps here.
Syvecs GPS2.JPG (679.3 KiB) Viewed 30239 times
Syvecs GPS1.JPG (683.85 KiB) Viewed 30239 times
Syvecs GPS3.JPG (581.64 KiB) Viewed 30239 times
