The latest VAG MQB AWD Base map which matches the latest firmware can be found below in Attachments
Please note this is only a base file for the device and we recommend you speak with your dealer about calibrating the unit based on the car setup.
This base map limits the Max duty to 70%, Some users of the Rs3 Kit from Iroz motorsport have the duty limits at 80% or even 90%. You will need to adjust in Scal to Suit
Latest Base Map
Latest Base Map
- AwdBase_RS3 1.14.SC
- (37.21 KiB) Downloaded 4377 times
1.18
1.18 Base map, must be used with 1.18 Firmware
- AwdBase_RS3 1.18.SC
- (42.89 KiB) Downloaded 4186 times
1.21 Base Map
For use with 1.21 Firmware
- AwdBase_RS3 1.21.SC
- (46.26 KiB) Downloaded 4050 times
1.23 Base Maps
For use with 1.23 Firmwares
- AwdBase_RS3 1.23.SC
- (51.46 KiB) Downloaded 4198 times
- AwdBase_RS3 1.23 X4.SC
- (51.46 KiB) Downloaded 4147 times
1.24 Base Maps
For use with 1.24 Firmwares
- AwdBase_RS3 1.24.SC
- (55.83 KiB) Downloaded 3993 times
- AwdBase_RS3 1.24 X4.SC
- (55.78 KiB) Downloaded 4036 times
1.25
For use with 1.25 firmware on X4AWD Units
- AwdBase_RS3 1.25 X4.SC
- (61.05 KiB) Downloaded 4085 times
Re: Latest Base Map
For use with 1.27 Firmwares
- AwdBase_RS3 1.27.SC
- (66.84 KiB) Downloaded 2245 times
- AwdBase_RS3 1.27 X4.SC
- (66.87 KiB) Downloaded 2306 times
Re: Latest Base Map
For use with 1.28 Firmwares
- AwdBase_RS3 1.28 X4.SC
- (72.44 KiB) Downloaded 1889 times
Re: Latest Base Map
For use with 1.29 Firmwares
- AwdBase_RS3 1.29 X4.SC
- (72.89 KiB) Downloaded 2226 times
