Latest Base Map
Technical Help / Firmwares for the Porsche 991.1 / 991.2 Awd Controllers
Locked
Latest Base Map
The latest Porsche 991 AWD Base map which matches the latest firmware can be found below in Attachments
Please note this is only a base file for the device and we recommend you speak with your dealer about calibrating the unit based on the car setup.
AwdBase_991 1.14.SC
(37.21 KiB) Downloaded 4344 times
1.15
1.15 Firmware base maps
AwdBase_991 1.15.SC
(41.62 KiB) Downloaded 4094 times
1.18
1.18 Base map, must be used with 1.18 Firmware
AwdBase_991 1.18.SC
(42.89 KiB) Downloaded 4371 times
1.21 Base Map
For use with 1.21 Firmware
AwdBase_991 1.21.SC
(46.26 KiB) Downloaded 4310 times
1.23 Base Maps
For use with 1.23 Firmwares
AwdBase_991 1.23 X4.SC
(51.46 KiB) Downloaded 3954 times
AwdBase_991 1.23.SC
(51.46 KiB) Downloaded 3872 times
1.24 Base Maps
For use with 1.24 Firmwares
AwdBase_991 1.24 X4.SC
(55.78 KiB) Downloaded 4136 times
AwdBase_991 1.24.SC
(55.83 KiB) Downloaded 4205 times
1.25
For use with 1.25 firmware on X4AWD Units
AwdBase_991 1.25 X4.SC
(61.05 KiB) Downloaded 4223 times
Re: Latest Base Map
For use with 1.27 Firmwares
AwdBase_991 1.27 X4.SC
(66.87 KiB) Downloaded 2310 times
AwdBase_991 1.27.SC
(66.84 KiB) Downloaded 1994 times
Re: Latest Base Map
For use with 1.28 Firmwares
AwdBase_991 1.28 X4.SC
(72.44 KiB) Downloaded 1543 times
Re: Latest Base Map
1.29 Base map
AwdBase_991 1.29 X4.SC
(72.89 KiB) Downloaded 1918 times
Locked
Return to “Porsche 991.1 / 991.2”
