Latest Base Maps
Latest Base Maps
For use with 1.21 Firmware
- AwdBase_YarisGR 1.21.SC
- (46.26 KiB) Downloaded 3628 times
1.23 Base Maps
For use with 1.23 Firmwares
- AwdBase_YarisGR 1.23.SC
- (51.46 KiB) Downloaded 3406 times
- AwdBase_YarisGR 1.23 X4.SC
- (51.46 KiB) Downloaded 3519 times
1.24 Base Maps
For use with 1.24 Firmwares
- AwdBase_YarisGR 1.24.SC
- (55.83 KiB) Downloaded 3451 times
- AwdBase_YarisGR 1.24 X4.SC
- (55.78 KiB) Downloaded 3644 times
1.25
For use with 1.25 firmware on X4AWD Units
- AwdBase_YarisGR 1.25 X4.SC
- (61.05 KiB) Downloaded 3841 times
Re: Latest Base Maps
For use with 1.27 Firmwares
- AwdBase_YarisGR 1.27.SC
- (66.84 KiB) Downloaded 1891 times
- AwdBase_YarisGR 1.27 X4.SC
- (66.87 KiB) Downloaded 1926 times
- AwdBase_YarisGR 1.28 X4.SC
- (72.44 KiB) Downloaded 1297 times
1.29 Base map
- AwdBase_YarisGR 1.29 X4.SC
- (72.89 KiB) Downloaded 1389 times
1.34 Base map
Base maps for Gen1 and Gen2 Yaris AWD 1.34 firmware
- AwdBase_YarisGR 1.34 X4.SC
- (31.31 KiB) Downloaded 532 times
- AwdBase_Yaris24 1.34 X4.SC
- (31.31 KiB) Downloaded 523 times
