Hey
I have the golf r pnp kit
I uploaded the bas map and still the same
I have this massages
"Warning :logbook parameters do not match calibrationview and clear the logbook...."
"Calibration error: crusie control required max pps......"
syvecs connected not in sync
Re: syvecs connected not in sync
speak to your tuner who supplied it.
They should be able to make the changes necessary if you cannot.
But first off you need to do what it asks and clear the logbook.
Hey
I bought it from my friend and trying to figure out alone or help from this forum.
Then clear the logbook and look in cruise control to see what aspect relating to pps it is not happy with.
Logbook menus disable
I downgrade the ecu to 1.699
And the same to the base map
Look like everything is ok but still New error: "Calibration error:crusie control request max PPS adjustment piston <max enable pps"
so once again, look at the cruise settings to see what it is not happy with.
And randomly going up and down firmware versions is not a good idea if you do not know what you are doing.
Now everything is ok no error
I'm also getting connectioncoreball errors.
