Fk8 Stall issue
gctech
Fk8 Stall issue
Post by gctech »
Hello
Can some one take a look at this calibration/logs , I am having the weirdest issue , everything works as it should but and only when the Clutch is pressed the engine will stall , example I can free rev the engine on neutral no clutch rpm will drop nice an smooth to target but if I press the clutch engine feels rough and rpm drop fast and engine stalls, this also happen when vehicle is been driven and down shift or sometimes up shifting stalls.
only difference in hardware from previous is a twin disc clutch from single disc CM450 to a CM725
I attached current calibration and two data logs one free rev stalling and other driving stalling
thanks
S7PLUS 1.756 - Honda Type R Base - FK8 - MPFI - FF-v1.00 stall test.SC
(630.93 KiB) Downloaded 370 times
2025-07-17 22-30-40 plus free rev stalling.SD
(826.44 KiB) Downloaded 387 times
2025-07-17 21-57-57 plus engine stallling issue on clutch in.SD
(514.17 KiB) Downloaded 368 times
Re: Fk8 Stall issue
given you say the only change has been the fitment of a clutch...sounds more like something very wrong is happening when the clutch is being depressed as opposed to any issues with a calibration that you say had worked fine before.
If you get someone in the car to press the clutch, can you rotate the engine over by hand ? Maybe pull the plugs out so it can turn over more freely.
Or maybe get an inspection camera into the bellhousing to get a visual of what's going on ?
But you aren't really logging any idle parameters, or enough to get a full picture. But nothing looks overly untoward with the logs, other than rpm getting pulled down and stalling.
But as you say it will idle happily without the clutch pressed, and it is only pressing the clutch is a problem, sounds like something there is causing excessive load on the crank when it is pressed.
I can't see if you have any sort of clutch switch enabled or doing anything.
Does it change at a specific point on the clutch pedal ? Or progressive with load ?
edit. Just looking at the Cal, there is nothing configured in the ecu that I see relating to a clutch input to the ecu. It really does sound like a mechanical issue here.
gctech
Re: Fk8 Stall issue
Post by gctech »
Found the issue, seized throw out bearing :shock: :shock: :shock:
thanks for taking a look tho
Re: Fk8 Stall issue
Unusual, but figured it had to be mechanical.
victorpatrick
Re: Fk8 Stall issue
Post by victorpatrick »
How about increasing the base idle duty and adjusting the overrun fuel cut and idle recovery tables to better stabilize RPM during clutch-in transitions? Slope Game
gctech
Re: Fk8 Stall issue
Post by gctech »
victorpatrick wrote: Sat Aug 02, 2025 7:39 am How about increasing the base idle duty and adjusting the overrun fuel cut and idle recovery tables to better stabilize RPM during clutch-in transitions? Slope Game
The problem was a seized throw out bearing , when it was installed it was overstrocking which yield to a premature failure
thomasfrank
Re: Fk8 Stall issue
Post by thomasfrank »
stevieturbo wrote: Fri Jul 18, 2025 11:03 am given you say the only change has been the fitment of a clutch...sounds more like something very wrong is happening when the clutch is being depressed as opposed to any issues with a calibration that you say had worked fine before.
Does it change at a specific point on the clutch pedal ? Or progressive PolyTrack with load ?
If the transmission is stuck, pressing the clutch will create an abnormal mechanical connection, putting the load back on the engine.
