Long tooth gap
Long tooth gap
Sorry to hog the forum folks. I thought I had sorted all my tuning niggles with Paul's kind advice but now have picked up a long tooth gap error. It has appeared when driving under boost/high rpm rather than cruise and does not appear to be cranking related. I did not get any cough etc but noticed it on the log. I ran a sync log following at the end of the run when I picked up the error (attached). What should I be looking for on the sync log to diagnose this? Any advice greatly appreciated cheers.
- LTG error1.txt
- (272.2 KiB) Downloaded 1170 times
Re: Long tooth gap
That's just the startup log, can you post the error log, go to "Device->View Sync Log" and then click on "sycnError" or press the "E" key.
Check you're wiring, plug latch etc the normal things, might be the sensor itself too.
Re: Long tooth gap
Thanks Paul I swapped on another sensor and no more error
