Air shifter
ford racing
Air shifter
Hi i have been running an msd rpm switch to activate an air shifter.but now want to activate the air shifter with the s8.is it possible to use an output to supply an earth to a relay at a given rpm
Re: Air shifter
In it's most simple form....shift light output.ford racing wrote:Hi i have been running an msd rpm switch to activate an air shifter.but now want to activate the air shifter with the s8.is it possible to use an output to supply an earth to a relay at a given rpm
