MAP Sensor readings
For Subaru Technical Chat
Arch
MAP Sensor readings
Post by Arch »
What sort of values should I be seeing with the engine not running and with engine at idle with a 4 bar sensor - thanks
Re: MAP Sensor readings
Arch wrote:What sort of values should I be seeing with the engine not running and with engine at idle with a 4 bar sensor - thanks
Atmospheric should be around 1000mbar, give or take.
and at idle, 200-600mBar usually.
Arch
Post by Arch »
Thanks guys appreciate the help
