DBW boost management
I've seen the guys in the US do similar stuff, albeit with BOV's, and most usually to vent air to reduce compressor surge but maintaining power and impeller speed
A solution to cover a few scenarios, but interesting all the same
https://www.youtube.com/watch?v=POoWJkWMC5I
Re: DBW boost management
Just uploaded a new version of S6 code for you then Stevie which has Supercharge bypass control
Its only a small update as big release is coming soon but this is perfect for what you are talking about
Hi Ryan
I wasn't looking to use it myself, just found it interesting what they were doing. I've seen a few guys talk about doing the same to keep impeller speeds down on turbo setups using a BOV. The DBW aspect probably gives more scope for control though, although I'd think it would need a substantial motor to be able to handle high boost pressures
I just like the keep it simple approach most of the time.
