Switch inputs
Switch inputs
If I want to wire in paddle switches do I just connect 5V to the input, so when the normally open switch is operated and closes, 5V goes to the input pin on the x10?
Re: Switch inputs
At a guess you have the choice of either a ground switch or 5v switch depending on whether the internal pullup is on for that input or not.
ie, if there is no option for an internal pullup, then it would have to use a "high" voltage to change state. But as the spec says all inputs can do 0-5v, thermistor and switch....really it's up to you.
As there is an option for internal pullup, you have the choice of pulling the input to ground, or feeding it 5v ( and turn the pullup off within the ecu settings )
if wiring....I just like bringing 3 wires to anything like that. It makes it future proof and covers all scenarios.
ie always 5v, sens ground and the signal back to ecy. If you only end up using 2 of those...no odds. If you need all 3 etc, you're still covered.
Re: Switch inputs
Thanks I'll do that.
For the pneumatic valves , do I run 12V to the solenoid and let the ecu ground the output effectively making the circuit and energising the solenoid?
Re: Switch inputs
Yup.Grabla66 wrote:Thanks I'll do that.
