MK2 focus RS PnP system Injector latency tables
gctech
Post by gctech »
Hello
I'm new to this syvecs system , I am trying to setup the base map with injector upgrade but I cant find the voltage offset injector table under fueling all I see is PW base tables
thank you
Re: MK2 focus RS PnP system Injector latency tables
Run Mode fueling, Corrections, Primary Injector opening time.
