setting up 36-1 crank pulley
				ford racing
hi i need some advice on setting up crank pulley.we r running 36-1 so in s cal have set 35 teeth 35 gaps but have got question marks next to settings for gap widths etc ,i thought the settings already in the generic single gap single cam were already set? any help much appreciated
						Re: setting up 36-1 crank pulley
I believe the question marks come up when you change something that might effect something else so it reminds you to check other things that the change may have effected, so for teeth setup if you have changed it from lets say 36 teeth to 35 teeth you would need to go and reset the tooth gaps so they add up to 360 again, the mins and maxes need to be reset also
for 36-1 setup you should have 34 gaps @ 10deg and one @ 20deg
Question marks are do not necessarily mean there is a problem at all, but if you have updated firmware version or changed breakpoints that affect other tables it can optionally highlight what's changed for you. The default settings are for 36-1 and should get you started, if you can't seem to make sense of it post your cal up for review.
Paul
Paul
