pavlo wrote:What's the lambda doing?
You mention in the PM that your getting a long tooth gap, but that is a crank sensor error state. Also the error will remain until cleared, so you maybe you picked up the error on cranking or initial startup. Check the logs and see when the error originated.
As for the misfire, you probably just need to map the car properly! If you're seeing your tooth gap error and feeling the misfire, are you sure you're nor just putting 2+2 together to get 9?
How is the wiring "good" around the crank sensor? I have found that VVT solenoid wiring can upset cam sensor signals on some occasions.
Thanks again. Good point re the long tooth error it was cranking related before I changed the cam settings and it has not reappeared after I cleared it.
I'm am reasonably sure that it is not mapping related but am all ears
 She was running like a dream on the 2L with same injectors, turbo and all other ancilliaries etc. AFRs spike lean during the mis as expected (16:1 see around 23 second mark in log)). I have disabled CLL and added fuel but this has not improved matters. There is a reasonable amount of ignition advance and MAP reading looks ok. I have attached a log of when the mis appears (note long tooth gap was still present then before I cleared it)
Here is a photo of the wiring. I have not wired up AVCS yet as keen to get to the bottom of this first. The harness sits on top of the fuel rail so away from the injector and ignition coils. Perhaps the alternator harness is too close? -will try moving that.
