air con
Re: air con
Standard loom adapter/wiring will take the aircon on/off switch in to the ECU, and then there is an output to actually control the aircon. The demand from the on/off switch is overridden by calibrated rpm and throttle positions, so you cen make sure it shuts don on WOT etc.
So, in short, my understanding is that yes you will, unless you rewire it.
