Hi Wez,
Not sure if it's just me but I have noticed that when trying to put in custom CAL names/labels ' CAL 1' can't be altered as it is underneath the heading so can't be clicked on.
This is the same on iPhone 4S, iphone 5s and iPad.
Syvecs iPhone / iPad App - Classic
Moderator: Wez
Re: Syvecs iPhone / iPad App Chat
Toyota Supra BoostLab S366HF - 821 rhhp / 644 ftlbs - Mapped by Ryan
Syvecs S6 with aftermarket DBW setup on Greddy Style Intake manifold. - SOLD 2017
Hello Steve,Steve wrote:Hi Wez,
I am assuming your on iOS7, this is a nice new feature from the gui changes Apple made, it will be fixed in the next release
Wes
Yes iOS7
As long as you know
As long as you know
I am also having the same problem on iPad mini using iOS 8.1.1 which is the latest version and also 2.1.4 of the syvecs ap. any ideas.secure wrote:I can't rotate the screen on IPAD mini? No landscape mode on ipad mini?
Rather annoying as I have the iPad dash mounted in landscape position.
I am working on a FIX for this, Apple in their wisdom treat the rotation on the iPad mini different to iPhone which it works fine on.Motoka wrote:I am also having the same problem on iPad mini using iOS 8.1.1 which is the latest version and also 2.1.4 of the syvecs ap. any ideas.secure wrote:I can't rotate the screen on IPAD mini? No landscape mode on ipad mini?
The plan is to have a dash lock function in settings so you lock out rotation and have it only work in lanscape mode for fixed installs.
awesome thanks Wez
Hi Wez
thanks for the latest version
Great work. The only issue I have noticed that when I rev over 5000 rpm the rpm field and gear sift lights freeze for around 20 seconds?
Thanks.Motoka wrote:Hi Wez
thanks for the latest versionGreat work. The only issue I have noticed that when I rev over 5000 rpm the rpm field and gear sift lights freeze for around 20 seconds?
Thats a new one for me, I will check out the code tomorrow.
Does the issue have every time you go over 5000rpm and does it move if you change the shiftlight settings?
it's every time I go over 5000 rpm thanks and yes it seems to be dependent on the gear shift settings
I am looking at the code now, are you using the custom cam stream or default stack stream?Motoka wrote:it's every time I go over 5000 rpm thanks and yes it seems to be dependent on the gear shift settings
Does it behave the same on multiple devices?
