Ok I think i come across to an end. There are still dark spots on my wiring.
I have changed B20 connector to new style connector. (I couldnt source b20 male) AVCS sensor shielded wires goes to ECU from this connector.
I have changed map sensor connector to use flex fuel sensor.
I have used oem ign 1-2 wire and ign 3-4 wire as map signal and intake signal for newage. I just swapped wires from ECU and F60 connector as well.
I have also added 4 new ignition and 4 avcs wires(+shotkky). Ignition wires to AUX  1-2-3-4 and avcs wires to Fuel 6 and Fuel 5. I'm not sure if FUEL 8 (idle -) is spare or not. I'm planning to wire dccd to fuel 8.
Dark spots are on the F60 connector. I'm not sure if i wire up pins 13-14-15-16 / 1-2-3-4 in a correct order.
Since i didnt install the engine yet I can not trace those wires. I guess pin 1 is ign 12v / pin 4 inj 12v / pin 2 idle and purge 12v and pin3 is purge gnd. pin 13-14-15-16  looks all looks like gnd but not sure about the order.
So at that moment I am wondering about my Syvecs
