Hi Guys,
Is this possible to setup in the Syvecs S6 PNP??? I have a car to map which has this combination fitted. With G11 setup, it runs (of course) only 360 deg sync. Would like to have it run in 720 mode!
Thanks,
Mark.
						G11 crank trigger combined with G10 cam trigger
Re: G11 crank trigger combined with G10 cam trigger
It is indeed. Upload your map.
Or if you're feeling confident, it's explained here.
Print out a Sync scope and it'll start to make sense
viewtopic.php?f=6&t=582&p=2936
