Putting a hole in the ignition map is not the way to prevent stalling on syvecs, since the idle strategy has a proportional ignition correction for idle error, and a general idle ignition compensation to reduce the advance when in idle (which is temperature and run time depenedant). So removing the hole in the table will give a crisper throttle response, because as soon as the throttle is oped a crack the ignition retard disappears and the engine responds much nicer.
Using the above means that your ignition corrections will always work around the current idle speed.
FP-Limp at 1.5 bar / 6000rpm
Jump to
- Syvecs Engine Control Systems
- ↳ General Syvecs Chat
- ↳ S6 GP/PnP Technical
- ↳ S6-I / S6Plus Technical
- ↳ S7-I / S7Plus Technical
- ↳ S8 Technical
- ↳ S12 Technical
- ↳ Syvecs Bluetooth Module
- ↳ Software
- ↳ Calibrations
- ↳ Technical Deposit
- ↳ Projects
- General Technical Forums
- ↳ Subaru
- ↳ Mitsubishi
- ↳ Toyota
- ↳ Nissan
- ↳ Porsche
- ↳ Dyno Talk
- ↳ Track Days
- ↳ VAG Technical
- Expanders
- ↳ X10 (Legacy - Gen1)
- ↳ X10 Gen2 Expander
- ↳ X20L Gen2
- ↳ X4 Gen2
- ↳ OEX - Oem Ecu eXpander
- Syvecs AWD Modules
- ↳ General Questions
- ↳ VAG MQB4 Range - Golf R7, Audi S3
- ↳ VAG MQB5 Range - Audi RS3 / TTRS
- ↳ Porsche 991.1 / 991.2
- ↳ Porsche 997.1 / 997.2
- ↳ Huracan / R8
- ↳ Nissan R35GTR
- ↳ Infiniti Q60
- ↳ Yaris GR
- ↳ CorollaGR
- ↳ Generic AWD Module
- Syvecs Accessories - GPS | Bluetooth | KT8 | Wifi | WMI | DI12 | Lam2CAN
- ↳ Syvecs 50hz GPS / IMU Module
- ↳ Syvecs 100hz GPS / IMU Module
- ↳ Syvecs KT8
- ↳ KT8 Rev3 Standalone
- ↳ Syvecs Wifi Module
- ↳ Syvecs WMI Module
- ↳ Syvecs DI12
- ↳ Syvecs Lam2CAN
- Syvecs Dashes
- ↳ Syvecs TinyDash
- ↳ Syvecs Edition Plex Dashes
- ↳ Syvecs D5 Dash
- Enhancements
- ↳ Feature Requests
- ↳ Request for Comments
- JT Innovations
- ↳ Toucan Display
- ↳ General
- Feedback
- ↳ Website feedback
