The current calc for displaying Lambda is shown below as per sCal :-
(x/1000)+0
You could use the following calc to convert into AFR :-
x*0.0147
I have not tested these myself but they should get you pretty close
Moderator: Wez
Wez wrote:OK looking at a MAP value the default is in mBar like all pressure readings, the default calc is :-
(1*x)+0 which is basically just x
To convert to PSI one mBar is equal to 0.0145037738, I would round this up to 0.0145 and use the following calc :-
x*0.0145
To convert to BAR use x*0.001, or if you want KPA you could use x*0.1
Thanks!Wez wrote:To convert Lambda to AFR
(x/1000)+0
x*0.0147
It should be fine, I will run through some tests here but not had any other reports of it not working.Tuscan_John wrote:Hi Wez, do you know whether the app works on an iPhone running IOS9? I had to upgrade my iPhone 5 and now a bunch of stuff including the Syvecs app has stopped working.
The best way to check sensors would be to compare what is displayed in sCal to what you are seeing on the App, it should be the same as long as the calcs are correct.speedjunkie wrote:I've tested a couple of the calculations and I believe they're pretty close. ............
Are you referring to the Android BETA App?I picked up a CarPC that runs Android and I downloaded the app. I haven't paired the ECU to it yet, but I did realize that it doesn't have a rotation function so the app stays upright on a landscape screen and doesn't show a whole lot. I'm going to see first if it will even pair and show info, because I can make calls through the stereo using bluetooth, but I can't play music from my phone through the stereo using bluetooth. I'm wondering if that means it won't pair with the ECU to show info, which would negate the whole reason I bought it. In any case, if it will show info from the ECU, do you think there can be a way to get an option of rotating the screen in the final version of the app?
