A new topic dedicated to the discussion of calculations within the App, post your findings on what works best for you, I pull some data across from the other threads to get this going.
FYI The app runs separate from the ECU, the datastream output is always the same unit regardless what unit you display within sCal, you can see this at the top of the datastream frame content window, the calc does not change even you select another unit type.
