Hi!
Can Subaru cruise and radio buttons used as an Syvecs input say "rolling start" or "calsw" ?
						Cruise/Volume s.wheel buttons
Re: Cruise/Volume s.wheel buttons
The cruise buttons are normally connected to the OEM ECU on the later DBW models. On the earlier cable throttle models the cruise was implemented by a separate unit which actuated a secondary throttle cable  - in that case you wouldn't be able to pick up the cruise buttons at the ECU. I don't recall seeing an OEM wiring schedule where the radio buttons go to the ECU but perhaps on the late model CAN bus cars there may be a message that could be picked up but it's not something we've actively looked for.
Audio buttons are like a CAL switch, with a resistive divider chain between pins 4 and 5 of the connector. The audio system does have a low speed CANbus system but this is not connected to the ECU.
Cruise control buttons also have a resistive divider between pins 6 and 7, with the main on/off switch between pins 8 and 6. No CANbus - connected direct to ECU.
Great info thanks!
