hello first post,
I have a syvecs s8 ecu on my hayabusa turbo,
I tried to switch between maps on it with the switch and its not working,
plugged it in to the laptop and it says cal1 off, if I go to map 2 it says cal 2 off and so on,
does anyone know how to get these back working
sorry if this is I the wrong section new to syvecs and the forum
HELP
Re: HELP
Hi!
It has been covered here. you may want to watch Syvecs help videos.
https://www.youtube.com/watch?v=6BoXPFxAzo4
Re: HELP
Are you saying this setup has worked and run fine for ages, with calibrations changing as expected with the switch ?eddie1888 wrote:hello first post,
Or it is a new setup that has never worked ?
