Yes...and both options take like 2 seconds lol ( ok, maybe 3 or 4 really )
Select the entire table, Maths, and multiply by 0.6 lol
restore global to 1.0
						Changing map for bigger injectors
Re: Changing map for bigger injectors
Change it back to 1.0Hodge wrote:So if I have the global at 0.6 I'm guessing if I was to adjust the entire fuel table instead I'd reduce it. How much would you recommend Steve?
Then go to the fuel map.
Hit key letters S then A (select all) then hit M then M (math > multiply) then type 0.6 and hit enter.
This is how you do what Stevie says.
Before
After (key strokes) highlighted 9000rpm 1100mb you can see it does what you want
S>A>M>M>0.6>ENTER
Only issue with just doing this is you have to then do the other maps listed under Starting tab which have their own amounts listed in m/s, same process can be followed.
Also.... if you use a Load Multiplier don't forget to do the Secondary Load Injection Time table
