Running a Diff Coolant Pump
mgc1985
Post by mgc1985 »
Hi all,
Forgive the potentially basic question, still learning the Syvecs systems.
I'm running a temperature sensor in the diff and need to drive a coolant pump when it exceeds a certain temp.
Is there a way of configuring the Fan outputs in SCal to achieve this?
The main question is changing ectmax in one of the fan on/off menus to differential temperature. If that's possible then I think I know what I'm doing!
Re: Running a Diff Coolant Pump
You can easily assign one of the Fan outputs to trigger an output based on diff temp seeing as you have a sensor.
ECT is Engine coolant temp.
Assign one of the universal inputs to diff temperature and use it ( or your base map may already have some assigned to this term )
Go into View, Customising options, Output Functions then the Fan output you wish to use.
Then select the input you want it to be based around.
this should explain some
https://www.youtube.com/watch?v=IVIdYESOuOQ
mgc1985
Post by mgc1985 »
Great, thank you.
It was the customising options part that I didnt know.
Much appreciated.
