Fuel correction for fuel temperature
Wastegate base duty correction for either ACT or AIT
Overrun fuel cut dependant on coolant so it can be reduced with idle speed to eliminate hunting on initial startup
Proper A/C function with extra ISCV duty before enabling A/C clutch
Push pull ISCV control for 3 wire ISCVs
RPM limit dependant on coolant temperature to prevent motor melting
Boost target modifier wrt coolant temp to prevent motor melting
Safety measures based on oil temp/pressure rules
Bosch LSU control (in progress I know)
That's all I can think of for now!
Feature requests.
Jolly Green Monster
Re: Feature requests.
ghost trace and lock to current cel would be nice
Yeap MAP Tracer with a freeze button would be nice really.
Datalogging MARK
Would be possible to have a datalog mark via a momentary switch? quite usefull when testing to have a "flag" in the datas....
Quick update I guess :
Bosch LSU - Probably will not happen due to hardware, but L2H2 support should be fine and cost is similar.
Safety measures on oil / water etc - Implemented as programmable engine trips (can choose on/off per cal position and limp or kill per trip)
RPM Limit ect dependancy - present as warm up limp mode and also over temp limp mode or engine kill
Lock to current cell - possible in SCal with Options -> Lock
Freeze button - Hit the space bar in SCal to freeze the current point
Datalog mark via momentary action switch - Try assigning the switch to the Lap Beacon function
More things in the pipeline....
I like the sound of these.pavlo wrote: RPM limit dependant on coolant temperature to prevent motor melting
It does already support low oil pressure/temp limp mode or engine off.
Coil Dwell time dependant on MAP would be nice please.
Is this in the pipeline?Proper A/C function with extra ISCV duty before enabling A/C clutch
Would also be nice to have a seperate Valet switch function (with limits for rpm, speed and boost) which would override any Cal selected with the Cal Switch .... or modify the Pit switch function to add the additional funtionality.
