Does anyone know if the Syvecs bluetooth module will work with the earlier Solaris ECUs? I want to try Syvecs module, but after buying I need to take a payday loans in Tennessee online
So, hope for your advices.
Syvecs bluetooth module question
Michael
Re: Syvecs bluetooth module question
They are one and the same.
Although I think I recall one oddity around RS232 comms on a batch of early models, only for a limited run though.
But I've one of Tim's Toucans running custom can via RS232 on a very early Solaris S6 without issue. So if it was a bluetooth module, it would be working fine the same way.
Minor clarification Stevie - it was a small run of S6 units that had no CANbus, so the RS232 echo was introduced as a work around.
Ahh right, knew there was some oddity, just wasnt sure what it was.TimH wrote: Thu Apr 23, 2020 7:35 pm Minor clarification Stevie - it was a small run of S6 units that had no CANbus, so the RS232 echo was introduced as a work around.
The BT module should work just fine on RS232 as said![]()
