I'm back again with questions
I'm facing to strang oil pressure fluctuation. It don't happen every day, but sometimes, one morning, oil pressure decide to fluctuate a lot. One or 2 day after it's perfect.... I don't understand what happen
Firstly I though about a faulty oil pressure sensor, but I noticed that AVCS sensor RH (VVT1) read the same fluctuation but not VVT2.
So I assume oil pressure sensor is not faulty.
I've changed AVCS camshaft pulley by OEM Subaru ones and I changed both AVCS solenoid too by original new ones.
Oil pressure sensor is under the alternator, directly on the block.
VVT1 mean right side (driver side for RHD cars) for AVCS sensor
VVT2 mean left side (passenger side on RHD cars) for AVCS sensor
Oil pump is 12mm OEM
For the moment I have no "VVT fail" and ECU don't go in safe mode when running, even hard.
Any idea about the cause of such erratic readings ? maybe the relief valve of the oil pump is faulty ?
Here my readings :
