Latest Base Map
Technical Help / Firmwares for the VAG MQB Range - Audi RS3 / TTRS
Locked
Latest Base Map
The latest VAG MQB AWD Base map which matches the latest firmware can be found below in Attachments
This base map limits the Max duty to 70%, Some users of the Rs3 Kit from Iroz motorsport have the duty limits at 80% or even 90%. You will need to adjust in Scal to Suit
AwdBase_RS3 1.14.SC
(37.21 KiB) Downloaded 3729 times
1.15
1.15 Firmware Base Map
AwdBase_RS3 1.15.SC
(38.8 KiB) Downloaded 3441 times
1.18
AwdBase_RS3 1.18.SC
(42.89 KiB) Downloaded 3517 times
1.21 Base Map
For use with 1.21 Firmware
AwdBase_RS3 1.21.SC
(46.26 KiB) Downloaded 3394 times
1.23 Base Maps
For use with 1.23 Firmwares
AwdBase_RS3 1.23.SC
(51.46 KiB) Downloaded 3520 times
AwdBase_RS3 1.23 X4.SC
(51.46 KiB) Downloaded 3421 times
1.24 Base Maps
For use with 1.24 Firmwares
AwdBase_RS3 1.24.SC
(55.83 KiB) Downloaded 3284 times
AwdBase_RS3 1.24 X4.SC
(55.78 KiB) Downloaded 3381 times
1.25
AwdBase_RS3 1.25 X4.SC
(61.05 KiB) Downloaded 3414 times
Re: Latest Base Map
For use with 1.27 Firmwares
AwdBase_RS3 1.27.SC
(66.84 KiB) Downloaded 1561 times
AwdBase_RS3 1.27 X4.SC
(66.87 KiB) Downloaded 1561 times
Re: Latest Base Map
For use with 1.28 Firmwares
AwdBase_RS3 1.28 X4.SC
(72.44 KiB) Downloaded 1157 times
Re: Latest Base Map
For use with 1.29 Firmwares
AwdBase_RS3 1.29 X4.SC
(72.89 KiB) Downloaded 1350 times
Locked
